2005 body swap to 2002 chassis
I recently started a project on a salvaged 2002 3/4 ton 2500HD chevrolete with a 6.0 and 4l80. I put a 2005 1500 z71 1/2 ton body on top of it. Since putting the body on and the harness I've been wondering about ideas for the radiator, and fans. I have the electric fans I could toggle up or purchase a aftermarket harness for. The radiator I assume came off a 5.3 considering it was the 1500 series is similar to the 6.0 In all ways except the oil cooler lines is there a adapter or conversion kit for this or do I buy a 6.0 radiator and cut the body to fit?last but not least I'm curious if the key ignition being from the 2005 body will it link up with the 2002 pcm? Or will I have issues with the pcm with this change?
I would just use the engine harness and all from the 05 if you have it and it will simplify a lot of things for you. If you plan to do electric cooling fans the harness off the 05 will already be there to add the electric cooling fans the only thing you would need to ensure that you have is the cooling fan fuse box and the harness going to the fans. The 05 pcm will also run the 6.0 and 4l80 just have to get a tune done to tell it the new specs. If you are wanting to do away with the cooler lines you can buy a block off plate. If you are wanting to add oil cooler lines just buy the oil cooler assembly and get a radiator that has a oil cooler on it and whatever else you need. The ignition key can be made to work on either pcm as long as you go through the security program to recognize the key.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
