08 suburban rubbing issue
Hey all,
I recently have been shopping around for new tires. I stumbled upon someone local to me selling brand new 20” wheels and 275-55-20 tires off of their 15 Yukon. The price was cheaper than new tires so I jumped on them.
Now the suburban had 265-65-18’s so I immediately installed a 2” leveling kit.
I still have slight rubbing issue. Not so bad that it’s doing any damage and it does NOT happen when the wheels are fully turned, just @ random turns.
Anyone have any thoughts to stop this?
Maybe wheel spacers for the front?
IMO you might need to do some light trimming. Wheel spacers aren’t good long term for your bearings or studs.
Check the DOT stamp on the tires if they were made in 15 they are almost five years old. Tread depth could be perfect on a tire that is starting to weaken due to age. Play it safe.
I highly recommend falken wildpeaks for an awesome all around A/T.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
