More on Newman's Fuel
MountaineerTom
From Jayski's
#12's secret? smaller carb?
With all the talk about Ryan Newman’s race strangling fuel runs of late it’s no wonder that many of his peers are frustrated to the point where they’re hurling accusations. But the story behind Newman & Company’s fuel secret crawled out of the bag and into the lap of TFR [Team Ford Racing]. The secret to the formula — bigger is not always better in Winston Cup. The NASCAR specifications for a carburetor allow a carburetor will flow up to 830 cubic feet per minute maximum. Newman’s men have found if they run a carb that flows 750 cfm that they give up only two horsepower to what the bigger carb delivers. That smaller carb, without 2 hp, brings the team about 0.5 miles per gallon extra in fuel consumption. Taking that 0.5 mpg and working it with the 22-gallon NASCAR-specified fuel cell, you see that Newman has an 11-mile cushion compared to his competitors. Meaning that Newman could run an extra seven laps at a 1.5-mile track, such as is found at Lowe’s Motor Speedway. Unfortunately for the Alltel team the secret is starting to filter out to some of the other teams, however, the power lost to the smaller carb is not quite at the level that the Penske motor men are capable of recapturing, but darn close. Give those who have started to experiment with the smaller carb a few weeks and any deficit should soon disappear.(Ford Racing)(10-13-2003)
Pretty cool, but I bet they don't like that that info is leaking out. :mad:
I know as a Penske fan, I would've preferred that info not leak. What I can't figure is that if it is so easy for that info to leak, why hasn't any info from the DEI restrictor plate program leaked yet, they've been dominate alot longer.
:mad: I was thinking the same thing as I typed that. Or maybe they're just afraid one of the Eurys or Earnhardts will just kick their butt if they find out who leaked it.
I'm surprised they went on this long with that secret... they've definitely pretty much blown everyone out of the water as far as fuel goes and sacrificing of the 2hp proved to not even matter...very smart guys :mad:
I wonder how that will affect his winning streak...he's still definitely one of the fastest cars out on the track, but being the fastest doesn't always guarantee the win... you win most races off the pit and fuel...should be pretty interesting from here on and out.
    B07
    B07
  • Who's Online   3 Members, 1 Anonymous, 771 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
