Aftermarket towing mirrors.
Hello all,
I just bought a pair of aftermarket towing mirrors for my 2018 hd w/t. The brand is Mostplus and the mirrors have the turn signals, back up lights, heat and power. I will be installing them tomorrow. But my question is will everything work without buying any harnesses, wires that didn't already come with the kit?
Thank you,
Seth
  • 2 months later...
Not likely.   Did any wire harness come with mirrors?
Darn, just realized he asked that way back in Dec 2019 and never came back
