2014 Silverado Contact Syncing Issue
So I have a new issue with my ‘14. I’ve had my phone synced with my radio since I bought the truck new. Today I noticed when I used my DIC to navigate to my contacts list to make a call it says “No Content Available”. My main radio display shows my contacts just fine. Just all the phone options in my DIC are grayed out. Anybody else run into this issue? I’ve unpaired and repaired my phone but the issue persists.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
