Old school meets modern
Hello,  I purchased some 80's K10 15" six lug wheels with the dog dish hub caps to put on my 2011 Silverado, but of course they didn't fit.  I am trying to find some wheels that will fit the truck and also the hub caps.  So far I haven't found anything that works.  Does anyone have a lead on where I can find something like this to complete the look I'm going for?  Any help is greatly appreciated!
This is the HD forum with 8 lug 2500 and 3500 trucks
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
