6.0 vortec swap on 5.3
snow-white
hey, so i have this 2006 Chevy silverado 1500 with the 5.3 and i recently i did a 6.0 vortec max swap on it and i noticed that once i step on it it picks up but when it gets  to 4500-5000rpm it stays there and doesn't change gears until you let go of the gas. I have replace the Maf sensor 3 times and i cant get it to work, by any chance does anyone know what the cause could be. Thanks
  • 5 weeks later...
If you have a decent scanner, check for codes stored. Ahead of that, check TPS output and MAP sensor. Either can cause delayed shifting like you're experiencing. The 4l60, since `94, has been completely computer controlled, so it's shifting control is dictated entirely by the PCM under normal operating conditions.
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 1,235 Guests (See full list)
