Halogen Light Upgrades?
F15DOC
So, I spotted an old post awhile back with a discussion on upgrading the headlights.
The dealer cost was ridiculous, I think I read around $1800 per side!
What I don't like is that the fog lights are halogen and are bright white and the headlights are that older warm yellowish light (dont know the actual freqs)
Has anyone found a simple bulb swapout that will at least match the color without the expense of swapping out the entire lighting system?
