Replaced my plastic/rubber steering wheel today with a leather one off of an LT trim level truck.   As noted in a few other posts, the controls from the replacement wheel will not work to control radio and DIC.... but I was really just wanting the leather.    Since the replacement wheel came from a wrecked truck (blown airbag) I decided to move all the wiring from inside my steering wheel to the replacement one.
Removing the airbag requires removing a 10mm bolt from each side of the steering wheel (behind plastic covers)..... but much easier than older models.   The bolt holding the steering wheel on is a T50 torx.... and to remove it, you need to apply some heat (hair dryer worked good) because it has locktite on the bolt.
  • 10 months later...
On 2/16/2020 at 2:15 PM, 2nazt said:
Can you get the heated steering wheel to work or no?  Looks great. I want to do this now to my CTB.
Did you ever find an answer to your question? I’m looking to do the same
I haven’t looked into it.
  • 4 months later...
Not to revive a old thread but I just added a leather heated steering wheel on my trailboss custom 6.2 and no the heated wheel doesn’t work. Does anyone know how to get it to work? I added this it hopes that it would control or access the menu in  the wams high country cluster I want to add.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 599 Guests (See full list)
