No Gear Light, No Start
06 Silverado 5.3 VIN Z 197,000miles
I went to use my Superchips programmer today and it began the process and said there was a communication error, reset and then said the vehicle was not responding. I called Superchips and they were helpful in getting me to remove fuses and such but no luck. They believe there is a problem with my ECM now so I have it out and sent in to return to stock, along with my programmer.
My question is, why even when the ECM was in, would my gear selector light not come on? It is usually a good indicator that the truck will jot turn over. I have had that a couple times now where if that light was not on I would disconnect the battery, hook it back up, and then it would turn over and fire up. But, if the light is not on it won’t turn over  or even try.
Why does this happen and when I get my ECM back should that take care of the issue too?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
