Upgraded Sirius XM module
MTMark
Just got a 2016 Silverado 3500HD with the IO6 and base Bose system. Does anyone know if you can upgrade just the Siriusxm component to one that has pause/replay capabilities?  My other rigs have always had it and I really miss it. Thanks for any help.
