1990 Silverado 1500 fusable links
I just bought a 1990 Silverado 1500  5.7  short bed 2 wheel drive, it would run if you poured fuel in the throttle body so I towed it home thinking it was the ign module. When we got home I tried to start it, no sound from the fuel pump or starter engagement. Started checking voltage and pulling covers off. The cover on the firewall that says fuel pump relay has a junction block mounted to fire wall. All the fusable links was cut out and some were wired together. I guess some pulled apart during the trip home. Does anyone know the amp rating and a schematic of where they terminate?
Thanks for any Help
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
