Green Dex-cool!?
I had my '98 Blazer in for a new alternator which
was replaced.
The dealer also said the coolant was low and they
topped if off and added a dye to help find any leaks.
About five hours later, I'm driving home and a
radiator hose pops off and leaks green coolant
all over the street.
I take the Blazer back. They reattach the hose
with a new clamp and charge me $42 for two
gallons of Dex-cool. The total bill was $90+.
Out of curiosity, I check the coolant. It is still
green. Should two gallons of Dex-cool (normally
orange) look green?
I go back to the dealer and tell him that unless
Dex-cool is now green, I think they put the
wrong coolant in my vehicle. The bring out
the tech who worked on my Blazer most
recently. He says he used Dex-cool and that
the dye made it green. After some questioning,
he said they add a vial of fluorescent yellow dye.
I'm still trying to figure out how mixing yellow
with orange makes green. Also, after replacing
virtually all of the dyed coolant, how is it
still green?
GM has two kinds of Dex-cool, there's orange amd greem, although the green looks a lot like a flourescent yellow I don't remember which kind the blazer takes. Maybe somebody on here with a blazer could pop the hood and take a look to ose what color thiers is. If it came wiht orange from the factory, then you should not put green in it, and if it came with orange and the dealer put green in it, they may have to flush the whole system and then refill with orange. I don't know the difference between the orange and green Dex-cools, but you can't mix them and they aren't substitues for one another, you've got to use whatever color was in there originally.
This Blazer definitely came with orange Dex-cool.
What color should Dex-cool be after adding a dye
to check for leaks?
There is an update to this story. A couple days
after this Chevy dealer reattached the radiator
hose with a new clamp and installed two gallons of
green "Dex-cool", the hose fell off again. It fell off
where they installed the clamp.
I called the dealer to ask what I should do.
He says, "we tightened it." Not too well, apparently.
They wouldn't even look at it until the following day.
They screw up the repair and they can't even
make a slot to get me right in. Nice service, huh?
Sounds like you have the most incompetent service guys ever lol.
The dexcool should be redish orange, and I don't believe that dye should've changed the color to green. If I were you I'd take it to a reputable serviceman and have the rad flushed now and have your coolant properly put in. If dex cool is mixed incorrectly it can become a nightmare.
Perhaps if the service manager doesn't react to your demanding a free coolant flush and change, Another GM Dealer could handle it and your Future Business.
I think GM and the B.B.B. would be getting a call on these guys! Perhaps if the service manager knows this they will correct it for you.
Squeaky wheel gets the oil! I would be very squeaky!
As for the color of Dex Cool, My '97 Blazer had the Orange Dex Cool.
My guess is they put the wrong stuff in.
I can't believe how much they charged to fix there scew up the first time!
was replaced.
I don't think you should have had to pay anything!
I'd take it back, talk to the Service Manager, if he's not interested then talk to the general manager of the dealership and get them to flush the system and refill it with the right Dex-cool. And this should be done at no cost to you, seeing as how it is their mistake that needs correcting.
If they still won't do it for you, take it elsewhere from now on and give a call to the BBB, and mention that you're doing both of these things to the general manager of the dealership.
Nick
The dealer doesn't admit making a mistake. They say the
yellow dye made the orange coolant green (even after it
came out and was almost completely replaced by another
two gallons of "Dex-cool"! [four gallons if you count the
water in the 50/50 mix]). By the way, my cooling system
holds three gallons.
They claim they tightened that hose clamp that fell
off 3 days later.
And they apparently didn't feel there was any urgent
need to fix their hose clamp that fell off. They felt I
could wait a day.
I took my vehicle elsewhere to be flushed and
filled with genuine Dex-cool. It is orange now.
The guy who changed it said the old coolant
looked "just like the green coolant they put in
the older cars."
Man you got lucky something didn't happen than what did happen. I don't know how long it takes for Dex to start gumming up when mixed with the green stuff, but when it does its a PITA on a grand scale.
  • 3 weeks later...
the only thing that happens when the 2 are mixed is that the 5 year life is now a 2 year life like the green stuff has always been.
in the gm tech manual
    Patrick Fergy
    Patrick Fergy
  • Who's Online   0 Members, 0 Anonymous, 788 Guests (See full list)
