Rattle from front right wheel area?
Almost sounds like a loose strut/shock would.
I wont be able to tear into it until Tuesday so I thought I would get some insight and see if anyone had an idea?
Its is horribly annoying.. when driving all I know is it comes from the right corner of the car, could be interior, but I am guessing a suspension component.
Anyone have the same noise/problem?
Thanks
Sounds like the same problem I had. It was the common steering shaft clunk. It just needs lubed to fix. There is a service bulletin about it. Mine was horrible before it was fixed under warranty.
This could be it... it definatly sounds like my front suspension is falling apart.
I will check in the morning and keep you updated.
If that isnt it, the HOE is going dealerside tommorow. I JUST CANT TAKE IT ANYMORE!!!!!!!!!!!!!!!!!!!!!!!!!!! :cheers::sleep::(:D:P
