How do I clear Engine codes?
Im trying to figure out if I have fixed my problem...How do I clear engine codes to turn off SES light. (without a scan tool) On my Jeep I could just remove the - ground from the batt for a few min. Is that the same for my 02 Tahoe 5.3L ???
Mike
if the problem was fixed the light woudl go away by itself after so many starts, even if unhooking the batery clears the problem out of memory the light will be back because there is still a problem
fix it
fix it
Right, I agree thats not going to FIX it...but I guess I was wondering if it will "Clear" it so when I do try a new part or whatever I can see if that was the problem without waitng the x-amount of "drive cycles" to see if problem was fixed
Mike
dont think the battery trick has worked since 1995models. Many states now pass/fail your emissions worthyness of your car based on the SES light. they dont want it to be that easy to beat the system.
Yeah, but your not really beating the system, for if the problem is still there....it will come back on.
I heard I can disco it for 15 min to clear...but I dono
I had a SES light come on in my 99 tahoe.. took it to autozone they checked to see what code it was and then cleared it.. no problems after that
Autozone will clear it if you fixed it. They cleared one on mine after testing it. The second time the light came back on, and a different Autozone, they didn't clear it, and I yet fixed it. Got a low flow code for the drivers side exhaust. May be because of a broken manifold bolt.
Fixed my girlfriends car that had the light and she took it in to Autozone for them to clear it. The guy first gave here some hassle about clearing it that she had to fix it first. After telling him three time that I changed her plug wires (misfiring, burned hole in one of the boots) then he cleared it.
You can buy a simple code reader that will read the active codes and clear them. Just surf around and for about 130 bucks you can get one.
You can also build you own cable, and there is lots of free OBD-II shareware and use your own laptop.
There is even software now that will give you a dash board output to your laptop, but
no one has the tech-2 software so you run diags and change parms.
I'd get the code reader, your going to need it again, and again and again anyway.
Yes, Just disconnect the battery for 15 minutes and that will clear codes.
If the problem that set the code still exist then the check engine light will come on again. Thats a real P.I.T.A. to do every time you think you fixed the problem and if you have several different problems kicking off the codes.
By the way if you fix the problem, The check engine light will clear it self out after a set number of driving cycles (don't remember the exact #).
A scanner is a valuable tool to have in your tool box with todays vehicles. The cost has droped over the years to be more affordable today.
I use the following:
http://obddiagnostics.com/
Free download of software
I purchased a cable from the site for around $ 75.00
(I could have built one for a few dollars less, But decided to get the pre-built version
I currently run the program on my compaq laptop running windows 98. I use to run the program in DOS running windows 3.1 on a old laptop with no memory or processor speed (freebe laptop)
You could also move your desktop out to the vehicle and rub the program in full color 32 bit processor. ( I did that one time and decided to buy a new laptop because it is a much better running program.)
Doesn't sound like a bad deal, I miss being able to use a Snap On scanner everyday in H/S if I wanted to on my truck last year. $80 sounds better than what I new scanner costs!!
99 2-door take a look at Dells, I've got an Inspiron 1100, way more than I need but not one problem at all :cheers:
If you don't want to wait 15min or so for the stored codes to lose power. REMOVE BOTH TERMINALS than touch the too DISCONNECTED cables together.
Yeah I have heard that works...
I have heard connect the 2 together and touch the brake pedal to "uncharge" anything
Mike
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 199 Guests (See full list)
