Gear question
OK so I bought all this stuff from Power Train truck and auto parts:
-8.25" IFS 4.10:1 OEM GM gears
-Front Master overhaul kit
-8.5" 10 bolt 4.10:1 OEM GM gears
-Rear MOK for eaton
-Eaton posi LSD
-new axle seals and bearings for rear
-two bottles of friction modifier
-6 quarts of gear lube
total to my door: $970
Here's the problem: They sent an 8.6" ring and pinion set for the rear. The one in there now is 8.5". I know the newer trucks use an 8.6" ring gear, but will it fit in my housing and work with my eaton posi designed for an 8.5" ring gear?
There are some pictures of the install at http://www.pswired.com/95yukon/performance...gears/gears.htm
-Patrick
