How to De-Badge?
Hey all, I'm wanting to de-badge my Silverado and was just curious what ya'll might advise for the most hassle free way to accomplish it w/o causing damage to the paint finish. Also any recommendations for a cleaner that will take sticker residue (caused from dealership stickers) off a truck w/o harming paint?
Thanks in advance! :cheers:
One thing I might add to the article Wingnut linked you to. Use Goof Off to remove the residual adhesive. I used it to clean the residue on my Z28 and it worked great. As usual try it in an inconspicuous place first. :cheers:
Try a product called "citrus solve". You will be amazed. Myself and everyone I have showed it to has been blown away by what it will do. It will remove the sticky gunky s**t left over by stickers and will remove the paint left from side swiping something. I am not a salesman just someone that has found a great product.
I guess the only place you can buy it is at a whole/natural foods store. I actually need to buy some more too. My ex used to work for a eco show and hooked me onto this product. At least something good came out of her. :sleep:
Faerge :cheers:
When I removed my Silverado and Chevrolet badgeing from the tailgate, I followed the method posted and I also used some road tar/bug/gum remover, worked quite well, just make sure you throw on a coat of wax once you are done with everything.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
