2004 Yukon Front End Problem
I have a 2004 GMC Yukon with 195,000 miles on it. For the past week I’ve noticed a Loud flapping sound coming from the left  front end it only happens when making sharp turns(left or right, in drive or reverse). It flaps faster and faster when accelerating while turning and it goes away when my front wheels straighten out. I recently got an alignment and a few months ago I had the front sway bars and front wheel bearings replaced.
