Wiring a light bar to headache rack
I have a 2020 gmc denali 2500 duramax and I'm trying to wire my flood light bar to my magnum rack so it works when I back up when the cargo lights are on. I had it wired on my 2018 denali 2500 to work like this but when I wire it to the lights in the bed on the 2020 it cuts out as if it's drawing to much power. Any ideas to as why or any info on a way to wire it so it stays on. Thanks
Use a relay to connect it..depending on bar size u probably are over drawing it
Sent from my Moto Z (2) using Tapatalk
1 hour ago, m denali said:
Where would I get and install the relay
Any chance you could post a pic of your truck with the rack?  I am thinking about adding one.  Thanks.
The wire attached to 86 will be the wire from the bed light
30 main power fused as needed
87 to light bar power
85 to ground
When ur bed light turns on it will turn the relay on and turn bar on
YouTube relay wiring for better understanding
    sqidget
    sqidget
  • Who's Online   1 Member, 0 Anonymous, 1,448 Guests (See full list)
