New brake pads and rotors squeal
So my 14' had the brakes and rotors replaced before I purchased it and I've been noticing a squeal/squeak when slowing down from 20+ mph. I took it back and the dealer said they would replace them under warranty, which they did for the front pair since they were suspect, but the same squeal is there. They weren't sure why and said it is common for certain brake pads to do this, although they wouldn't upgrade them. I've been driving it like this for a few weeks now, so not sure if brake bedding is necessary at this point, but I have a feeling it wont go away on its own. Its not constant and requires a certain pressure/speed on the brakes in order to make the sound, but when it does, it drives me crazy. What brake pads are yall running and do you think its worth the trouble for me to spray the back of the new pads with some brake silencer, or just go ahead and put different pads on it? Thanks.
If they used a lower quality pad or something like a semi metallic pad, I could see that being the reason for the noise.
I really like the Adaptive One pads from Napa or even their mid grade Premium Safety Stop pads. I've also run power stop's ceramic pads before with no noise at all. Wagner makes good pads too.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 929 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
