Wheel swap
Just bought a 2020 Silverado. Want to do a wheel swap change stock 18s for 22s. Do any of the older model wheels fit. I have a set of stock 22 that hit the redesign caliper before sitting flush.
Very few fit. It's not so much the offset but the angle of the spokes. What wheel are you wanting?
22 hours ago, dram1983361 said:
You could try 1/4" - 3/8" thick spacers to push the wheel away if your dead set on using the wheels you have.
I wouldn't plus even a 3/8" spacer won't work on that wheel.  Running anything larger than a 3mm (1/8") then the wheel becomes lug centric and not hub centric. Lug centric is relying on the lugs to center the wheel instead of the hub.  FWIW, GM wheels don't like being lug centric. The hub is around 8mm thick and if you use anything larger than a 3mm spacer,  with the taper on the wheel bore and the hub taper, there won't be enough hub left for the wheel to slip over the hub and grab.  3mm is the max spacer to keep the wheel hub centric.  That wheel shown by 4x4silverado will need a min. 1/2 spacer.  You won't have enough lug left using a 1/2" spacer.
I reached out to Custom offsets and 3/8 is the max you should go according to them when it comes to a "slip on spacer". Only thing I would add is extended thread lug nuts  to get more bite/thread engagement. The spacers have a lip on them just like the stock hub so the wheels sits exactly like stock extecpt pushes outward. Hub centric. Now if these specific wheels need more space than what 3/8" gives, then O.P . would need a thicker spacer that has lugs built into them and would need to trim the stock lugs(depending on thickness of the spacer) or get different wheels all together. Might be easier to sell the old and get new ones.
If the spacer has a hub on it that's ok.  The only spacers I've seen with hubs are the ones with lugs on them.   Anyway, I'm not a fan of spacers.  I always just get wheels that fit.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 431 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
