295/60/20 spare tire
I'm looking to replace my spare tire with something of equal height on my 2019 Silverado. Anybody happen to know if I can fit something the same height (295/60/20) where my current spare tire is located? Before replacing my wheels and tires I had factory 20s so I believe the current spare rim is a 17x8.
Not exact size but close. I don't remember what sub forum it's from but I took screen shot.01fbe9f6e866e4529c52ca959db493db.jpg
Sent from my SM-G960U using Tapatalk
Perfect! Thank you so much
