I recently took the factory bed liner out of my 2017 1500 but now I need the screws for the tailgate cover, any idea what size they are?
If you go to your dealer, start with this part number, 11570637
Thanks but they want almost $11 a piece for them and they come in a pack of 10. No thanks... lol What are the sizes for the p/n 11611882? I'll try and find them elesewhere?
Same size, these are the part numbers when you do not have the liner, the longer liner screws have a different part number.
I would check with another dealer, I found them sold induvial around the Seattle area. They were only a couple of bucks each, somebody is making up a lot of missed sales at $11.00 each.
Quote
I'll say....that's why I always try and avoid factory parts...tooo xpensive. Thanks for your input.
On 5/22/2020 at 9:34 AM, BleedBowties said:
You are very welcome.
They are the same screw that holds in your tail lights, fender well liners and so on, they are every where on the truck.
Take one out and go to hardware store, Fastenal, anywhere with odd size fasteners.
Edited by JimCost2014
  • 2 years later...
The correct part number has to be 11570637, as I bought a couple of them two weeks ago. The problem was that I couldn't find any of those screws at the local dealer. I had to order them and wait for them for almost a week, which is pretty frustrating. Someone actually told me that you could use the best bugle batten screws there as they fit perfectly, and they are much cheaper. My brother has actually done that, and it seems like they are working fine. However, I still think using the original part is much more reliable.
Edited by NeoxReeq
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 552 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
