Installing splash guards with fender flares?
I bought front and back OEM molded splash guards for my 2016 Silverado and was debating on getting the below fender flares as well. Does anyone know if its possible to install both since they seem to overlap in the same spot?
Thanks
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
