Air Lift Controller Mount
I just bought air lift airbags with the compressor for my 2017 Silverado 1500. I am looking for a different place to mount the controller for the compressor rather than under the steering wheel. I want a clean, stock look. Anyone have suggestions on where to mount the controller so that it is hidden? I was thinking inside the center console or the top glove box but unsure of how to run wires to those areas. Thanks!
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 800 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
