Leveling
Anyone using the Daystar spacers on a 03 Z71 Silverado? Do you have to get a re-alighnment and does this stiffen the ride any? Do you have to do any other mods to use these spacers, and how big of a job is it? Also anyone with pics of there truck with this done? And last but not least any warranty issues in doing this?
Hey,
If you got a Z71, you got a suspension up front which is different from the 2wds that have a coil spring type suspension. What you should probably do if you're looking to level out the front end of your truck is get some Ford Keys and crank your torsion bars. I don't know the specifics of the process but just look up Ford Keys or torsion bars in this forum or the 4x4 forum and you will definitely find the answers because this has been gone over a buncha times. Also you do need to get your front tires aligned after you let the suspension set in. Good luck.
Say
