2015 Yukon Denali power window passenger
barto
Ok, I've tried to track this thing down and I'm running out of ideas.
1. Checked all the fuses I could find (drivers panel, passenger panel, under hood).
2. Replaced both driver and passenger switches.
3. Checked the battery 12v and ground cable.
4. The shop tried a new motor.
The odd thing is that the door opening doesn't activate the dome light either. Yes the flat switch is set and all other doors activate the lights.
Switch is illuminated.
Today, the power mirror is no longer adjust. Signal in mirror works, blind spot monitor. I'm thinking it's wiring in door jam.
