Sirius Radio Presets not saving
Just bought a used 2018 Sierra.  Put in Sirius favorite channels, press and hold to save all 14 favs.  Next day, they're all gone.   Same again next day.  Anyone know why they are not saving?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
