Radio Won't turn off / Door Open Sensor Issues
Looking for some advice on where to start sorting the problem out. Originally, radio would not turn off when exiting/door opening and windows would not function from any door. Unsuccessfully left battery unhooked overnight. Problem somehow randomly resolved and worked properly for awhile but has now reoccurred but a little different. Radio still will not turn off with door opening after key turned off (will time out) and windows will operate but only from their respective door. Driver's door will not operate any windows and the door open stays on the dash. I believe there are 2 relays associated with door opening but unsure of which ones? OR is it BCM failing? Any help/advice appreciated? Thanks.
It happens to more of us then it should. Idk that anyone found a resolve. That said...
After you park, turn the engine off, get out and press the lock button on the drivers door. Close the door. Does the horn honk and everything shut off once the doors lock?
Sent from my LM-G820 using Tapatalk
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
