Clearance help
I'm putting on Fox 2.5 coilovers and Kryptonite UCA's on my 2016 GMC Z71. And before anybody blasts me I've looked and looked, but is anybody running these UCA's with the factory 18in U spoke wheels with a 265/70r18? If so any clearance issues? Also thought about going to 20in wheel with 275/60r20 tires. What offset and backspacing should clear without any trimming?
Thanks
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 701 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
