Hi all,
My 2014 Silverado 1500 LTZ has an oil level warning come up on the centre console. The dipstick shows plenty of oil (it's just has 8 quarts put in at the local dealership) so I'm thinking it is the oil level sensor.
My problem is I'm struggling to find the part online. Does anybody know the part number?
Edit: is this it? https://www.wholesalegmpartsonline.com/products/Chevrolet/2014/Silverado-CREW-CAB-LTZ/Engine-Oil-Level-SENSOR-SWITCH/10488077/12639127.html
Edit: this looks like you have to remote oil pan to replace. I was hoping the oil level sensor was one of the screw in ones from the side of the pan. Could anybody confirm? And if so what part I need.
Thanks everyone.
Edited by Stuart W
