Tires?
GF7PE
here is a good one for anyone that rides beaches or sand. We all know that a bald tire is the best for sand. But, has anyone used a mud tire on sand? I want the aggressive tread for snow and mud but still need good floatation. I had the BFG atko's and they were awesome all around but I still want something a bit more aggressive. I went with the Nito Terra Graplers but they kinda stunk on the beach and were ok in the snow (bgf atko's much better)
P.S. am thinking BFG MT
Ideas? Thoughts?
I dunno about a bald tire being the best for sand...but I have swampers on my blazer, and goodyear mud's on my HD....both of them perform flawlessly. I always air them down to around 15 PSI.
I think your driving style has a lot more to do with it than your tires.....I've pulled out more than my fair share of Jeeps, minivans, trucks, and SUV's, where people started to dig in and they floor it thinking it'll get the out faster....
I know here in FLorida where you can drive on the beach the sand is like pavement...but where I go fishing and driving in NC on the outerbanks....if it there hasn't been a good storm in a while....the sand is deep and loose. After Isabel this year though I was out there, and there was a cadillac out there.....it was like concrete....and no fun at all.
Well the sand here is very loose and soft and the hardcore beach guys use old airplane tires. They are pretty much bald and float on top of the sand. The big lugs supposedly dig thru the sand, but I havent tried them yet
but you are saying that the do work, Have you ever compared them to the atko's?
I really would like the mt's for the snow but.....
I used to have BFG At's on the blazer before I got my swampers, and they performed great in the sand also....I aired them way down also. I will say that the aggressive tread does tend to dig a little, but that's when you just back out of the gas. You have to understand also....I'm not trying to act like my truck is a sand rail,(although I did get a ticket for speeding on the F-ing beach.....40 in a 15).......when I want to go fast, I need to ease into the gas, I can't stomp it or it will dig in, but that doesn't mean I don't try once in a while :thumbs: Make for a very sandy truck though....inside and out
    Matt Parker
    Matt Parker
  • Who's Online   2 Members, 0 Anonymous, 898 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
