silverado a/c
my electronic a/c dash control/display went blank,leaving me w/out any climate control. is there ahidden relay or fuse i should check?
His profile says its a 92. I would like to know how this turns out because the display on the 94 seems to hesitate just a bit on start up sometims here.
On my 92, it was going a little goofy from time to time.....Buttons not working at all....Some buttons working some of the time.....Other times, everything was peachy.
No amount of "percussive maintenance" would get the a/c on to cool my temper when it acted up either.
I removed the panel (and the whole control box that is attached to it), and took it apart. There was a layer of translucent rubbery stuff covering the circuit board that I had to peel off to get at it. Once I did, it was an easy fix....Kinda like doing the wiper motor. Just a couple points of contact on the board that the solder spots had popped off of, and were only intermittantly making contact.
I just cleaned them up, and dropped a new drop of solder on them, put it back together, and popped it back in.
That was around 5 years ago, and it still works perfectly.
I'm no electrician, so you know it isn't a hard job.
Even if you don't have a soldering iron, it would be cheaper to do it yourself.
Soldering iron - $12.50
Solder - $3.50
Band-Aid for cuts on hand -$2.49
Not paying $120 + 2 hours labor at the stealership for 3 cents worth of solder, and 15 minutes worth of work..........Priceless.
Hope that helped a little.
Solder - $3.50
I have even seen kits (-bandaids) for like 7$ with everything included at RadioShack.
At least when mine goes crazy I think I can figure it out. :cool:
Just be careful, and mind your temper, and there wont be a need for the band-aids. :cool:
It was the not careful part that did me in :D
Solder - $3.50
LMAOROF!!! :cool:
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 181 Guests (See full list)
