Has anyone changed the fuel pump in their 2003ish 8.1L?  Mine is starting to make a noise and I want to replace it as preventative.  Curious what part number is best as I don't want to do this job twice!
I have a 2001 8.1L.  My sending unit was acting up so I just replaced the pump and sending unit as an assembly.  I went to napa and bought whatever they had.  Its been in there since 2008 so far.
As a note, Lift the bed instead of dropping the tank, its way easier.
When I did the pumps on my truck, I compared the tops of my existing pumps with new ones on rockauto, so it had the same number and orientation of connectors on top.  I have a cab&chassis with a wood deck that I can pull up the boards to have a look and work on them, so it was easy for me to look at them.  You might be able to reach up with your phone and take some pics or a video of the pump from underneath the truck...
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 850 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
