Good Evening All,
I have a 2014 Silverado 1500 LT Z71. Aftermarket LED headlights and tail lights. Never have had any issues with them but yesterday my running lights just randomly stopped working. My low beams come on but that is it. No side markers up front and no brake lights in the back when I'm in drive or when I remote start the truck. The brakes work when pressed but at night they don't light up until they are pressed.  Turn signals work up front and in the back. Reverse lights work. License plate light works.
I saw a video on youtube of a guy who has a 2016 who had the same issues in the rear and he bypassed it using a butt connector but it wasn't detailed enough for me to do based off the video and quality. Doing that also wouldn't fix the fact my front running lights won't work (the amber blinkers). I could live with the front ambers not lighting up but I'm more concerned with the brake lights not illuminating in drive at night.
I know the running lights are controlled by the BCM. Is there a good chance this has gone bad? Anything I can do to test and see or is this something I need a dealer to test.
Looking for any suggestions. Thanks
So the fuses were blown. Replaced and they blew immediately. Replaced the relay and the fuses again. Fuses blew again. So I’m assuming some sort of short. Could it be the bcm. Any suggestions?
Hi I have a 2018 gmc sierra 1500 and tailight running light doesn’t work and the front daytime running light doesn’t work on the right side and also I tried to install an aftermarket led tailight but when I connected it I smelled some burning what could be the problem thank you
  • 5 months later...
Was this issue resolved I’m having the same problems as Ludgero with the right side running lamp in the rear and front DRL is not working.
Hey guys any update running into the same issue with my 2017 GMC Sierra and this is the only article I’ve found so far , all my lights work like , break , reverse , left signal, but my light doesn’t stay on for break and the running light around the normal lights up front.
Edited by Gmctrucks0848
  • 9 months later...
having an issue with my daytime running lights. only one of the 2 on each headlight come on. the bottom one on the passenger side comes on and the top one on the drivers side comes on. But when I hit my lock and unlock button on my key fob all 4 come on. I checked the 2 fuses for the drl's and they are both fine. anybody have any ideas on what to check next?
  • 2 years later...
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
