I recently purchase a 2015 Sierra 1500 SLE, and am now getting the trailer brake warning whenever I start it. Watching Youtube videos suggests it is either the control switch or Relay. Rather than replacing one or both of those, is there an easy way to just install to the P3 controller I already have form my last truck? Would a truck with th e factory controller installed be setup for a plug and play install? Any advice is welcome - thanks!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
