Alright gentlemen. I have a 2004 Chevy Silverado Z71 with a 4.8 330,****** miles 6 inch pro runner suspension lift with 35's
My camber is  EXTREMELY negative when backing up only. Pull forward it is fine. I have replaced driver side hub bearing, inner and outer tie rod, pitman arm, idler arm and bracket, and cv shaft in March 2020, re-did entire suspension in Summer of 2018 which included both hub bearings, cv-shafts, upper and lower control arms, sway bar end links, outer tie rods. I have had it aligned at two different shops recently and the problem still persist. Also in August 2020 changed camber bolt and plates on driver side. With all this being said any insight is appreciated as to why my camber is negative in reverse only.
