Hello All,
Quick question.  Both of my outside mirrors on my 2004 Silverado 2500HD are shot - I have electrical tape holder the driver's side glass in.  These are the smaller electric extending side mirrors.  They are quite expensive to replace +$300 each.  These are my second pair.
Any recommendation on a viable alternative to these I like the taller ones that have the two panes of glass.  I am okay with manual extending but would like whatever I use to have the turn indicator and be heated due to the winters where I live.
Any recommendations/experience with swapping out for a different type?
THank you
Actually, I have had good luck with stick on Adhesive backed replacement mirrors.  The are just a piece of glass mirror that fits directly over the cracked mirror. Mine have been on for over three years, with no problem, and even defrost/defog in our harsh winters up here in MN. Gogle your vehicle Dorman makes them for almost every vehicle.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
