The service front camera came on for my 2017 Chevrolet Suburban with about 60k miles. I installed a replacement camera and now I need to calibrate the camera. I can't seem to do it with my Autel scanner ( no programming module which could be why?? )
Then I hear the dealer has a software update fix for this which will cost me about $150 tomorrow, however my codes don't match the ones in the tbs about the software upgrade.
DTC U0121-71 and U0134-00 are showing
I am going to pay for the software upgrade and hope it fixes it. At this time I believe the camera itself may not have been faulty at all but I will know tomorrow.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwi5_IO0jK3sAhULmHIEHbimDkoQFjABegQIBBAC&url=https%3A%2F%2Fstatic.nhtsa.gov%2Fodi%2Ftsbs%2F2016%2FMC-10096225-2280.pdf&usg=AOvVaw3Va6G2HoFvyk9HV97bo3kF
Anyone know about this issue?
