Intake Verdict
I am looking for a decent cold air intake system, however am finding so many options out there I do not want to make the wrong decision...anyone have a link to a review site, or have experience with any intake system that they are absolutely sold on? Thanks for the help, I have a 5.3 in my 2002 Sierra Z71. Thanks again. :rolleyes:
I have the K&N setup on my Serria Denali 6.0L.
Pros:
Great power increase
MPG improved 1-2mpg
Looks cool when you pop the hood
re-usable filter
Cons:
$250
Increases the chance of hydralock
More engine noise (not a con for me, but some like a quiet eninge bay. With the K&N you hear the air sucking in, similar to a quadrajet when you nail the gas)
Overall I highly reccomend it and would buy it again.
:rolleyes:
I have a Volant air intake, I had 3 K&N FIPK's on my last three SUV's and wanted to try Volant, I will buy Volant again, it was made better and the fit was better than my last three K&N systems.
The Volant filter still has an enclosed air box correct? From the pictures I have found, that is what I come up with. I found one for sale on e-bay and the guy wanted to sell me the "ram air kit" for an extra $100. Is this a Volant option and is anyone running the ram air with the Volant? What about running the truck through deep rain water, is there a chance to suck in water with the standard Volant box? Thanks
I have the Volant ram air on my '00 Sierra. The ram air tube pulls air thru the tow hook opening in the air dam. I've only been running this set-up for a month so I don't have any long-term experience with it, but I really like it so far. It's a closed system so it's quieter than some of the other aftermarket products, which I really like. No problems with rain.
I have the AEM Brute Force intake on my 01 Z71. It is loud, but that is what I was looking for. I also like the look of it since it is a 5 inch chrome tube. It has also been just fine in the rain. The box shielding that replaces the old shielding protects it from rain getting too the filter, but the air is still available.
You do not have to remove the tow hook; the intake tube is shaped to fit the opening with the hook in place. Without the ram air tube, the air is pulled thru the fender, same as the stock box.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
