New tires
GF7PE
Which if these would be best? In your opinion..
10 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok lets see what everybody thinks
3-4 months on snow powder, slush, hard packed and ice
4-5 months on beaches air down to 12-15 lbs
the rest all asphalt
about 10k miles a year
:D ? You should go back and edit the options.....You left off Firestone AT's. :devil:
If you spend that much time in snow, and in the sand, I think you should go with something more aggressive than the ATs. BFG always seems to do the job.
Just my .02 :devil:
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,150 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
