I just redoo my brakes on  2015 Silverado  3500 and front brake almost metal on metal rear brakes  almost new.
Its that normal after only 60000km?
My old truck 2007 silverado 3500 I did my brakes after 150000 km and still was like 25% left but all wheels  wear the same.
Teach what can be the issue?
