Anyone know where to get a "pair of nuts"? Lol
I am switching to the 6112's, and the shop told me the nuts should be replaced as well because they are cross-thread on the current 5100s....
1 hour ago, Snowcamo said:
Offerup or dealer maybe?
Sent from my LM-G820 using Tapatalk
Had a duh moment. got 2 ordered and should be at dealer friday.
Oh hey while your ordering stuff
Please swap the two top plastic strut mounts. Seen a few here where they break shortly after install?
ordered new strut mounts on amazon the other day. Couldnt find the ones put together in stock, and when they are, they sell out quick. Ordered from Battleborn offroad from reviews and told them my situation. ( Strut mount on the left broke)
They understood and managed to ship same day. Best customer service ever.
got these
got these
Man that sucks. Looks like you'll be set for some time.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,188 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
