So I just installed a K/N cold air intake and now I am getting codes P0101 and P0102. Could it be just a bad MAF sensor or possibly damaged from me handling it incorrectly? Would a new MAF sensor work?
2014 GMC Sierra 5.3 liter 145,000 kms
Edited by Kpalmer
Is it a brand new filter or did you clean/re-oil an old one?  MAFs don't being contaminated with oil (which can happen when you overdo it on the recharge.)  I'd give it a quick clean before thinking about replacing it.
Brand new filter however I didn’t oil it yet. I’ll try some cleaner first
Good idea.
I cleaned mine with a q-tip and denatuered alcohol.
Just hoping I didn’t pull on a wire to hard on the connection or something. Hope it’s just got a little dirty or worse I broke one of the fine wires inside the MAF
Bought some MAF sensor cleaner and gave it a pretty good spray however still showing the codes. Ugh!
FIXED! i installed the MAF sensor upside down.
gonna disconnected the battery for 30mins and hopefully it will delete the permanent code P0102
What did you do exactly cause I have the same issue
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,138 Guests (See full list)
