I am looking for any information on wiring harness is for a 2020 RST crew cab with a Bose system. I am having a shop do work on my truck and I want to give them as many tools as possible so they don’t cut my wires. If anybody please has information I am looking to add a sub amp and woofers and also a four channel for the highs and mids on the factory head unit. I have not seen on the Internet that they make an aftermarket head unit I am not trying to lose my functions to the truck. I am also looking for any information on wire diagrams for the doors and the tailgate. I do not want to add an aftermarket alarm because i don’t want to use a different key pad! I want my Chevy key fab! I want shock, tilt, glass break. I have seen on the InternetThat you can add these sensors to the factory alarm. Just by tapping into the doors of the truck. Does anybody have information on this also.
