Just introducing myself to the forum. I’m a previous owner of a 2004 Silverado 1500 Z71 Extended Cab. My father owns an old 2001 Silverado 1500 Single Cab Long Bed work truck. I’m now the owner of a new 2020 Silverado 1500 Crew Cab Standard Bed Z71 LTZ. I’ve installed the GM Chrome Steps, added the stake holder caps/covers, installed a Bed Rug Impact Bed Liner over factory sprayed bed liner, and added a painted to match Undercover Elite LX tonneau cover. My truck is North Sky Blue with just about every option available, I think. My next add will be the GM splash guards for the front and back. Hope to have them installed in a week or so.
