Hay everyone
so my 08 Sierra with a 5.3 has been throwing a CEL for fuel trim issues
1 code it will say bank 1 Lean
and then another time it will read bank 1 system imbalance bank one
so my long term fuel trims are around 20% both banks
I have looked at the mV for the o2 sensors all read roughly 500-700 mv if you floor it the pre cat 02s will dip to around 40-100mv
post cats stay roughly the same
I’ve sprayed around the intake and injector area with carb cleaner and water, didn’t get any results leading to leaking gaskets
maf was cleaned
CEL started appearing when it was around freezing weather, and wouldn’t turn on until it cooled down and re warmed up
I don’t know where to even start being I don’t believe it’s a underperforming o2 sensors
as it could be a large air leak or a underperforming fuel pump causing a lean issue but it only throws a CEL for bank one?? But both banks at at 20%???
Maybe check the exhaust manifold/exhaust pipe for missing bolts or leaking connections ahead of the O2 sensor?    With my LQ4, it's common for the manifold bolts to break off, and on my truck, a number did and the exhaust would draw air in, making the O2 sensors read lean.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,388 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
