I have a 2006 Suburban 1500 4WD Lt. is not lifted. All OEM, no add on's. I noticed a sound radiating from the driver-side yesterday ( FRONT Driver side). I was in 4 "Auto". My impression is 4 Auto, you can drive in this mode without damage, the system activates when it detects rear wheel slippage and engages the front drive. We have roads here that are mostly snow covered. I had it in 4 Auto, the sound was a low slight rumble sound. ( Best I can describe like when a Wheel bearing goes bad and running out of grease driving straight). I hit 2 WD, the sound goes away, pressed 4 HI, the sound returns. No noise turning, if I accelerate, the noise increases, decel- same, noise fades. I can feel it through the steering very slight. Its more audible...Whats the chances its a WB? I replaced one when I bought the vehicle but I think it was front. pass. side. Weird its in 4 Auto when the drive isn't engaged? Any ideas, I am open to anywhere to start, I was going to jack it up, loosen hub nut, do the 6 and 12 shake, 9 and 3 shake, try to determine bad WB first. I feel its not the WB because the 4 WD has to be on to hear it. I will take any solid advice. Thank you all
if it were a wheel bearing I would expect it to make noise all the time. Might be front shaft U-joints.
I have a 2008 2500HD and had a simiar noise coming from mine.  Difference though, mine was happening in 2WD, but not at first in 4wd.  Took it to the shop, and told them it almost sounded like the axle shaft was rubbing on the shock mount.
Later to find out, my CV joint out at the drivers side wheel had come apart.  They replaced the CV joint, put it all back together, and no more noise.  Maybe that is the issue?
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,184 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
