I just bought a 2018 Sierra 1500 slt a few weeks ago, yesterday I went to shut the wiper off and they don’t stop. They work on high and normal speed but no intermittent. I can’t find a relay for it in the manual, do I need to replace the switch?
Edited by Mike Ransone
Incomplete sentences
The wiper relays are PCB relays and are built into the fuse box.. 1 for low speeds and 1 for the high speed. Its either those relays or the bcm that controls them.
Well, I talked to the local GM parts department and they said I can change out the relay, so I did and that didn’t work. I changed out the switch and that didn’t work. Really don’t know what else to do. None of the area dealers have a fuse box as they are all on back order. It’s past the 36,000 mile bumper to bumper warranty.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
