I was driving around 40 mph and engine light comes on. I pull over and check the codes- p0711 Transmission fluid temperature sensor and p0700 Transaxle control system malfunction. Now the transmission is shifting at weird rpm’s and jerks at low rpm’s. Any suggestions on what that’d be?
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 829 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
